Browse Forums Pools & Spas 1 Oct 30, 2018 12:55 am Hi, I would really appreciate advice or opinions as to what has happened to our spa. We have had it for two months and used it a handful of times. We emptied it to change the water and came back to see this damage! It’s like the acrylic has puckered and split. The edges are sharp. What would cause this?! I will get on to the supplier tomorrow but would be very grateful for any thoughts as to how this happened. Is it a manufacturing flaw? Thank you in advance. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: HELP! Spa surface ruined! 2Jan 18, 2019 10:58 pm Hearing such a thing for the first time. It looks like some acid damage. Usually acrylic sheets are impact-resistant and abrasion-free. Even if you hit it with a hammer it wont break easily. It will be neat but you won't have much freeboard. At least they are not weep holes. Are you in a high intensity rainfall region? The regulatory slope is only required… 3 8285 You can wash over existing pavers with 10% solution of water and hydrochloric acid, then wash off. The acid will provide for required bond key with new concrete. 1 36968 |
