Browse Forums Pools & Spas Re: Raise ph to bring it down again 6May 28, 2018 10:45 am aussieta oh dear, you have been pool shopped as an experiment take a sample to each pool shop in your area or have a friend bring in a sample from your pool an hour later and pretend it is from their pool, note ph will change and free chlorine will be slightly lower more than an hour later and compare the results wander over to troublefree pool https://www.troublefreepool.com/content ... e?tabid=40 and learn what you need to know their premise is in quality testing and adding only what your pool needs usually using chemicals from box stores like bunnings you will require a quality test kit either taylor k2006c http://www.poolvacparts.com/taylor-fas- ... -size.html or clear choice labs https://clearchoicelabs.com.au/product/ ... alt-water/ you need the fas-dpd test my chemical usage went from $100-$300 per pool shop visit to $150 per year with salt water generator there is a lot more to looking after pool chemicals to keep it safe not just algae free after a short time you will learn how each chemical works in relation to other chemicals if you arent sure just post your test results and what kit you used and the experts will advise you how to proceed i cannot have enough praise for how much i learnt at TFP here is a post i made of my clean pool before and after TFP https://www.troublefreepool.com/threads ... -after-TFP at TFP your water is clean if you can drop a coin in the deep end and tell if it is heads or tails Re: Raise ph to bring it down again 7Nov 15, 2018 12:31 pm Hailsm aussieta oh dear, you have been pool shopped as an experiment take a sample to each pool shop in your area or have a friend bring in a sample from your pool an hour later and pretend it is from their pool, note ph will change and free chlorine will be slightly lower more than an hour later and compare the results wander over to troublefree pool https://www.troublefreepool.com/content ... e?tabid=40 and learn what you need to know their premise is in quality testing and adding only what your pool needs usually using chemicals from box stores like bunnings you will require a quality test kit either taylor k2006c http://www.poolvacparts.com/taylor-fas- ... -size.html or clear choice labs https://clearchoicelabs.com.au/product/ ... alt-water/ you need the fas-dpd test my chemical usage went from $100-$300 per pool shop visit to $150 per year with salt water generator there is a lot more to looking after pool chemicals to keep it safe not just algae free after a short time you will learn how each chemical works in relation to other chemicals if you arent sure just post your test results and what kit you used and the experts will advise you how to proceed i cannot have enough praise for how much i learnt at TFP here is a post i made of my clean pool before and after TFP https://www.troublefreepool.com/threads ... -after-TFP at TFP your water is clean if you can drop a coin in the deep end and tell if it is heads or tails Thanks for your advice I'll definately head over to that page and do some reading thank you. I've never been a fan of pool shops and their way of making money, every time I've had water tested at any pool shop they tell us to raise the ph super high to only bring it back to neutral. The only reason I'm getting the pool shop to test my water is to get the print out records for warranty purposes on the pool shell. Hi, realize I'm a bit late to the conversation, what was the final result? Interested to know Thanks Matt ok thanks - yes was wondering if that should have been listed as Option Three! 2 7743 i had the my concreters concrete right up to the fence. I have pits all along my path, so the water tends to drain away from the house and into the pits. There's only one… 7 12776 How long is a "long period"? For a few weeks, it should be ok. It also depends on the area you live in...I would let your neighbours know that you will be away too and… 1 28574 |
