Browse Forums Pools & Spas 1 Feb 21, 2018 9:35 pm Hi, Short Version: Is a fully compliant permanent pool fence required for an inground empty pool, in order to get a house COO? Long Version: We're building a new house, and pool at the same time. The house and pool are under different builders and permits. We want to get a certificate of occupancy and complete the house, but the pool is a way off completion. We realise we have to have a fence to stop people falling into the empty pool (still under construction). Are we able to use a construction type temporary fence? If not, are we able to rent a pool compliant temporary fence? Or are we required to have a full, permanent installed fence? We are in Victoria. Cheers + thanks, Sxwallac. Re: Pool fence requirements for COO (not for filling) 2Jul 07, 2018 5:36 pm Hi SXwallac. You can get a temp fence converted into a temp pool fence.... depending on what current temp fence type you currently have. If you've got those 6ft Mesh panels... you'll have to change them. Re: Pool fence requirements for COO (not for filling) 3Jul 16, 2018 7:24 pm Thanks Guys. We rented a temporary pool fence to be safe. We got the COO no problem (although that doesn't necessarily mean that it was all good: we just didn't get pulled up for it). It did cost us a few hundred bucks, but at least it didn't delay the house COO. Cheers, Scott. DIY, Home Maintenance & Repair But if it is a ground level open pit, then it is not a charged system. No surprises there. The pipes have obviously been altered and there would be a reason for this.… 3 31601 That was always going to be a challenge and a test of patience. Full marks to your mate. Did you discuss the wet area near the trampoline? 16 17705 This was on google. Development controls 2.3.1 Front setback D1 New buildings within residential areas shall adhere to a front building line, which is 5.5-6m to the… 1 3872 |
