Fiberglass Pool Bleaching under the water line
Page 5 of 5
How do I send photos on this site?
I don’t think the gel coat restorer with a buffer will work (it didn’t for me) it’s meant to restore the finish on a fibreglass boat hull - not strip off chlorine bleached gel coat from a pool wall.
Thanks - going to try your procedure - I believe there are some options when you reply to a post including attachment - But have not done before - do you mind if ask another question once I try a section next week?
And I’ll be interested in any replies to your general post (about long term damage)
The gel coat is quite thick and I assume you are only removing very little with very fine sanding.
But I felt like I had nothing to lose. I’m not sanding through to the actual fibreglass
Sure.
Thanks this. After posting on this forum a long time ago I had given up. Based on your post I will this a go this summer. I’ll share my results too. Thanks again for sharing!
Sure.
Hi - just looking for an update - I did a section last summer - wondering if your area is still holding up - thanks
https://pooladvisor.com.au/blog/remove- ... ns-in-pool). Go ahead and buy some and see if it works!
The vitamin C pill is basically just ascorbic acid. Many pool shops sell stain removers that are essentially just ascorbic acid for the purpose you described above. They're pretty decent for copper looking stains (as per I installed a new pool heat pump to my pool about a year ago and I'm sure that's when I started seeing my pool stain in the white substance all around the pool floor and walls.
I also think having a pool heater connected through the sanitizer does spike up chlorine levels but not sure.
interested to know how many of you have pool heaters connected.
also has anyone made any advances in resolving this issue?
Thanks for your time.
Hi all I am looking to run a water line under my concrete footpath which is directly next to my home, was seeing if this is possible without cutting the entire section…
17/06/2023
Hi everyone, Looking for some advise. We are about to build an above ground pool in our backyard. There is a private sewer line running under the pool at 1.6m…
