Browse Forums Pools & Spas Re: Fiberglass Pool Bleaching under the water line 85Jul 27, 2021 11:47 am TPG Sure. And I’ll be interested in any replies to your general post (about long term damage) The gel coat is quite thick and I assume you are only removing very little with very fine sanding. But I felt like I had nothing to lose. I’m not sanding through to the actual fibreglass Thanks this. After posting on this forum a long time ago I had given up. Based on your post I will this a go this summer. I’ll share my results too. Thanks again for sharing! Re: Fiberglass Pool Bleaching under the water line 86May 27, 2022 11:19 am TPG Sure. And I’ll be interested in any replies to your general post (about long term damage) The gel coat is quite thick and I assume you are only removing very little with very fine sanding. But I felt like I had nothing to lose. I’m not sanding through to the actual fibreglass Hi - just looking for an update - I did a section last summer - wondering if your area is still holding up - thanks Re: Fiberglass Pool Bleaching under the water line 87Jul 02, 2022 5:54 am I have calcium or bleaching. I took a vitamin c pill, cut it in half, and rubbed a white area above the waterline. Surprisingly it did a fairly good job of removing the white. I can’t clean my whole pool with half a pill. Does anyone have any thoughts on a different way I could use vitamin C to clean the pool. Not joking. The pill really did work. Re: Fiberglass Pool Bleaching under the water line 88Jul 04, 2022 9:47 am The vitamin C pill is basically just ascorbic acid. Many pool shops sell stain removers that are essentially just ascorbic acid for the purpose you described above. They're pretty decent for copper looking stains (as per https://pooladvisor.com.au/blog/remove- ... ns-in-pool). Go ahead and buy some and see if it works! Re: Fiberglass Pool Bleaching under the water line 89Jan 19, 2024 1:28 pm This issue is also happening in Victoria to me! I would like to know how many of you with this issue has a electric heat pump pool heater connected running through the sanitizer ? I installed a new pool heat pump to my pool about a year ago and I'm sure that's when I started seeing my pool stain in the white substance all around the pool floor and walls. I also think having a pool heater connected through the sanitizer does spike up chlorine levels but not sure. interested to know how many of you have pool heaters connected. also has anyone made any advances in resolving this issue? Thanks for your time. Re: Fiberglass Pool Bleaching under the water line 90Jan 19, 2024 2:49 pm I have been installing automated systems only for 4 years now and havnt had a single problem . Running a heater without orp sensors is a a accident waiting to happen Hi all I am looking to run a water line under my concrete footpath which is directly next to my home, was seeing if this is possible without cutting the entire section… 0 20184 Hi everyone, Looking for some advise. We are about to build an above ground pool in our backyard. There is a private sewer line running under the pool at 1.6m… 0 11760 4 10822 |
