Browse Forums Pools & Spas Re: Fiberglass Pool Bleaching under the water line 33Nov 26, 2018 1:37 pm KazBoo Thanks aussie's - but what exactly do you suggest I look at on that site? I have since found out that it is a manufacturing fault most likely, with a batch of gelcoats around the same time our pool was put in, but the pool companies are using too much chlorine as an excuse not to uphold their guarantee! So basically we are stuck with a fadiing pool after only 2yrs and the pool company won't own up! I will be investigating further and contact Consumer Affairs! I would be very interested to hear from anybody else please with this problem. Please feel free to msg me. thanks. Hi Kazboo - we have a barrier reef pool which is also only 2 years old. Same deal as yours - fading below the waterline. The chlorinator provided by the pool company is an automatic one so we don't really need to do anything with regards to the chlorine levels. we do monitor them and they have always been fine. never off the charts at - in fact ours is the other way round. I have seen a number of post regarding the same issue by barrier reef pools on a product review website but doesn't look like people have much luck fighting it. Where did you hear about the manufacturing fault? Re: Fiberglass Pool Bleaching under the water line 34Dec 16, 2018 1:27 pm We have had our Pool in for 3 years now and noticed the same problems we have a water mark all the way round the pool plus when it’s low we have fading/chalkywhite all over the pool below water level. It’s only seen when the water level is low. The gel coating also doesn’t feel as smooth too. We got it from Riverina 🙁 Anyone had any luck with them offering assistance? Re: Fiberglass Pool Bleaching under the water line 35Dec 16, 2018 3:01 pm Rachris We have had our Pool in for 3 years now and noticed the same problems we have a water mark all the way round the pool plus when it’s low we have fading/chalkywhite all over the pool below water level. It’s only seen when the water level is low. The gel coating also doesn’t feel as smooth too. We got it from Riverina 🙁 Anyone had any luck with them offering assistance? Hi, which state do you live in? Ask Riverina first but they will probably ask you for water test results and will tell you that your chlorine level had been high even if it is around 3ppm and tell you the cause is due to chlorine bleaching. And also tell you that water results from pool stores are not accurate and the best way is to measure it by the pool service man on the spot. There are too many people (regardless of water quality) having similar issues after 2-3 years that makes me think if root cause is the quality of the gel coat rather than how customers maintain the pool chemistry. Re: Fiberglass Pool Bleaching under the water line 36Dec 16, 2018 3:15 pm Hi JBP We are in WA. I was thinking the same thing that if there are quite a few people in same situation after 2-3 years could it be a gel coating issue??? We had someone out to look at the pool about a year or so ago and they said it was a build of metal plating which could be down to the actual water we fill out pool with. (This was Riverina). They said nothing could really be done to remove it and the gel coating wouldn’t have been compromised. But is was only by chance that the water level got really low that we have now seen the fading and how bad it really is 🙁 quote="JBP"] Rachris We have had our Pool in for 3 years now and noticed the same problems we have a water mark all the way round the pool plus when it’s low we have fading/chalkywhite all over the pool below water level. It’s only seen when the water level is low. The gel coating also doesn’t feel as smooth too. We got it from Riverina 🙁 Anyone had any luck with them offering assistance? Hi, which state do you live in? Ask Riverina first but they will probably ask you for water test results and will tell you that your chlorine level had been high even if it is around 3ppm and tell you the cause is due to chlorine bleaching. And also tell you that water results from pool stores are not accurate and the best way is to measure it by the pool service man on the spot. There are too many people (regardless of water quality) having similar issues after 2-3 years that makes me think if root cause is the quality of the gel coat rather than how customers maintain the pool chemistry.[/quote] Re: Fiberglass Pool Bleaching under the water line 37Dec 16, 2018 3:38 pm Hi, I had a local pool guy coming in and he sent the photo to one of pool manufactures that he knows of and was told that it’s probably due to incorrect spraying of gel coat during manufacturing. Mind you that my pool bottom also showed distinctive spray patterns as well as chalky walls since about a year ago. I believe that the pool was around 2-3 years old by that stage, put in by the previous owner. I am not sure if anyone was able to successfully claim the faulty gel coat. There are pretty bad reviews on Barrier Reef pools as well and I was even contacted by someone living in Melbourne who was trying to prepare to sue the company for the exact same reason. I was never contacted again after that though. My local pool guy also told me that he has seen similar issues on pools around my suburb as well. It seems like this issue is becoming very common. Re: Fiberglass Pool Bleaching under the water line 38Jan 17, 2019 7:56 pm My pool started going like this 6 months into it. Brand new 3 layer spec gel coat which on my paperwork is impervious to UV and water.. Guess what it is 4 years old now and looks rubbish. We have now called the manufacturer and they will be coming out with the pool seller and the gel coat guys. My brand new pool with this new Gelcoat rubbish is terrible. Our readings were done from day dot every month. We stopped using the pool blanket after we got one high reading so it would never happen again. Our readings are at an acceptable range which would make our pool look like the picture above. We are getting all our facts and sheets organised and will be going to the Building Commission if there is no fix. My contract and papers say What this NEW fan dangle gel coat was all about. The UV has attacked it and it is now blistering as going yellow, the white is white as can be and I no longer have glitter in my pool. I called the pool man out over a year ago and he told me to wet n dry sand it and handed me a tub of fibreglass polish and told me to polish it. No way! So in Feb they will all come round because the manufacturer said NO to sanding which I didn’t do and couldn’t believe what I was told. I have been told now as I have just got a maintenance guy in (who used to test my pool when I first got it) he has NEVER seen a new pool look like a 15 year old one. I will go Buidling Commission and go ACCC if I have to because what a waste of $30k Re: Fiberglass Pool Bleaching under the water line 39Jan 17, 2019 8:14 pm It’s also a salt water pool, solar heating ... The cell is always clean and no calcium build up either. I’m spewing, I have maintained my pool, and the people over the road do nothing with theirs and let it go green and all, they don’t even vacuum it and it’s looks brand new still and theirs is older. Re: Fiberglass Pool Bleaching under the water line 40Feb 05, 2019 1:55 pm Hi, I hope someone can help (with facts here)
We have a similar problem and the Pool Company have just washed their hands of it. Our daughter has been unwell . She was unwell last summer and now this summer and we have had many tests done, and it may be our pool We are not sure, we just want to be able to eliminate it from our own investigations. Just our pool (as she had swimming lessons during winter and she was fine then) We have asked the pool company many times if our pool is safe to swim in and they have avoided the question. They also have not put anything in writing (ie to tell us for sure what the problem is) - If they had said that it is safe to swim in in writing then I don’t think I would be here now. They have said over the phone that it is Chlorine Bleaching. But no explanation of when it happened, how it happened or even why it happened or how to fix it and if there are any health concerns. I think it maybe have been a problem with the gelcoat and they are trying to cover it up. But how are we supposed to know? Also our pool was built on a day that it rained and in 100% humidity (which is making me think that the pool did not cure completely) - And they did not want to release the manufacturing date, in fact they made it extremely difficult to get it? Our pool surface also has "Cobalt blue" in it which is a toxic substance. (I have not been told this, I have had to get the pool surface tested) Has our gelcoat broken down and is it breaking down into the pool? So many questions and they have all " gone quiet " and avoiding the issue. Which when our daughter is sick , and they know, and have told the gel coat manufacturer not to talk to us either! (as we have tried to ask them the content of the gel coat, and how it is applied etc...) All we are looking for is answers and they need to be facts , not just opinions. Our pool is now just 2 years old. We have been asking for answers for 7 months now. We are guessing that there are more out there, and not aware that there might be health issues that could be associated with it , not just cosmetic. Even if it is just cosmetic, our pool is just 2 years old! Disclaimer : Everything I have posted above is the truth, I am only thinking that my daughters health has been affected by the pool, because of the tests that I have had completed, and the reluctance from the pool company to answer any of my questions and to answer whether my pool is safe to swim in, despite seeing the daily "balanced" water reports and still not providing a written report to say what is wrong with my pool. The photos are in no way made up, and neither is the content above or the age of the pool. I am here just looking for facts on the subject. Pool one and Half years old WAPerth WA Fibreglass PoolLike ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Pool 1 and half years old, Perth WAPerth WA Fibreglass PoolLike ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Hi all I am looking to run a water line under my concrete footpath which is directly next to my home, was seeing if this is possible without cutting the entire section… 0 20178 Hi everyone, Looking for some advise. We are about to build an above ground pool in our backyard. There is a private sewer line running under the pool at 1.6m… 0 11757 4 10821 |
