Browse Forums Pools & Spas 1 Mar 24, 2017 7:47 pm Hi just got problem for the chlorinator. It always shows "Low Salt Level". It is a Chloromatic machine. Two led lights alway on when running. Based on the manual, it means salt level is too low, or cell needs to be cleaned, or water temperature is too cold. I have added quite few salt inside the pool. Tested the pool water in Bunnings. The salt level is normal. The cell has been cleaned recently. Water temperature is 22 C, so no problem. Anyone know how to fix the problem? Thanks. DIY, Home Maintenance & Repair Thanks. I was thinking of using either Extreme Joist or LOWDECK timbers for joists. Any idea what sets them apart and which… 2 12877 Thanks! I'm spoke to the builder I'm not sure if this is all true but basically went along the lines of they considered all options and if I was to compact and fill it… 2 6388 If you can calculate the reasonable charged head from let's say 100mm below the gutter to the top of where the vertical riser's horizontal discharge pipe will be, that… 11 17525 |
