Browse Forums Pools & Spas 1 Feb 22, 2017 1:05 pm Just considering which water blade to purchase for a new pool. The pool is 7m with a 1.6m spa on the end and we've decided to install a 2.4m water blade with 25mm lip. It appears there are two companies making/ supplying these in Australia (Austral and Waterblade). Austral - white plastic with no lighting $600 Waterblade - clear plastic $990 Waterblade with RGB LED's $1520 Waterblade charge $150 delivery based in WA, which is included in these prices. Obviously a huge difference in price. Has anyone had experience with these? Will the white plastic stand out too much (using a black quartzite stacked stone wall underneath)? How effective are the LED's - is it possible to retrofit some after market ones afterwards? $500 more for these seems crazy! Any thoughts are apprecaited. All sorted guys. Just needed to buy a blade with the correct bush. Dunno how to delete this post, can't find any help file. Cheers. 1 3667 4 10824 This certainly doesn't look good. I would be engaging with an independent inspector to have a look at this. As for the unscheduled site visits, most builders are quite… 1 28327 |
