Browse Forums Pools & Spas Re: Should we try and lift a fiberglas pool out of level? 21Jun 10, 2016 10:51 pm Not out of the skimmer box . The stand pipe next to the skimmer box . It is the black agg pipe in the concrete about 700mm to the right of your skimmer Re: Should we try and lift a fiberglas pool out of level? 22Jun 10, 2016 10:54 pm wheeliworks Not out of the skimmer box . The stand pipe next to the skimmer box . It is the black agg pipe in the concrete about 700mm to the right of your skimmer Sorry mistype that's what I meant there is a pipe that goes all the way down. Lol I have learnt so much thanks to this issue' viewtopic.php?t=78985 Re: Should we try and lift a fiberglas pool out of level? 23Jun 14, 2016 5:17 pm Have you managed to pump out? Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Should we try and lift a fiberglas pool out of level? 24Jun 14, 2016 5:56 pm building-expert Have you managed to pump out? Hi Building expert, we did try to pump out the water from the standpipe and it just kept filling up again so after a few attempts we stopped trying, got a bit worried if the pool levels drop too much. We had a pool leak detection company come today to check the pool out. They believe the leak is from the Hydro static valve after some investigation. They are coming tomorrow morning to fix the valve. Interestingly they asked us to drop the water level a bit so they can dive in tomorrow, when we did this leak and water around the pool has disappeared. Hopefully fixing the valve will resolves the issue. Still waiting on the structural engineers report. viewtopic.php?t=78985 Re: Should we try and lift a fiberglas pool out of level? 26Jul 08, 2016 11:52 am Franky40 Hi all, Just as a matter of interest, what is engineer's recommendation how to return pool levels back to tolerances? Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Thanks for the informative response! I'll feed that back to the site supervisor. 2 4122 isn't a garage level with the rest of the house a given? pretty sure they 'came around' long time ago. if you have a flat block, the garage is usually level with the rest… 1 17525 they can, it's a fairly standard solution when the slab isn't recessed. the falls need to be in the main floor, if it hasn't been done then you need to ask them to redo… 4 6584 |
