Browse Forums Pools & Spas 1 Dec 11, 2015 6:42 pm Hi All, Currently about to build a house and we are unable to put the pool in after the build because of access issues. The builder has said that it is best to get the pool placed in before the earth works start; need to cut and fill the house footprint also. I'm thinking if the pool is dug out and placed before the cut and fill it will cause problems for the pool stability as it is 1.8m from the back of the house. The building company is sending out a surveyor to peg out the pool area with datum heights, but i'm concerned once the earthworks start this may shift the pool. I would have through the earth works would be done first then have the pool dug out and placed. only placed her cause not many people read the pool section. Re: Pool placement before earthworks? 2Dec 11, 2015 8:22 pm Aussie141414 Hi All, Currently about to build a house and we are unable to put the pool in after the build because of access issues. The builder has said that it is best to get the pool placed in before the earth works start; need to cut and fill the house footprint also. I'm thinking if the pool is dug out and placed before the cut and fill it will cause problems for the pool stability as it is 1.8m from the back of the house. The building company is sending out a surveyor to peg out the pool area with datum heights, but i'm concerned once the earthworks start this may shift the pool. I would have through the earth works would be done first then have the pool dug out and placed. only placed her cause not many people read the pool section. We haven't built a pool yet but I believe you can do piering on the pool or the house to stop movement. Building a modified Madison 39 with Clarendon Homes in Tennyson homeone link: viewtopic.php?f=31&t=79106 Blog Link: https://minandb.wordpress.com/ Re: Pool placement before earthworks? 3Dec 12, 2015 2:14 pm Pool builders usually prefer to do their bit after the slab has been laid. It gives them a fixed point to work off. Otherwise the slab height turns out different to the plans they usually get the blame. Re: Pool placement before earthworks? 4Jan 21, 2016 1:04 pm Hi, we got ours dug our and concreted before the house (that's what out builder mac jones stipulated) then it was covered over and fenced and house was built. Levels have all turned out to be the same. Pool Is 1.5 m from the house (has ended up about 1.2m) only problem now is pool Company won't come back to finish the pool and we have been living here three months Buildingthegardenretreat.blogspot.com.au Hi all, My first post, we are building a house and can’t decide the layout of the lounge room. We have a large N/W facing window and are wanting to have a wood slow… 0 13759 Move your linen into laundry and access laundry from your present linen space 1 8060 I am in the same situation, would you be able to give some insights in to this? I am in SA 8 17092 |
