Browse Forums Pools & Spas 1 Nov 19, 2015 3:46 pm I have an old concrete, steel, vinyl lined pool that is in good shape, but the surrounding old pebblecrete slab needs to be restored. This will mean removing the pool fencing while the job is being done (pumping and pouring a fresh concrete slab) around the pool. I've heard that for any work around a pool, it needs to be drained! Surely not? Any advice on if I need to, or how I can keep it safe for qualified concreters to do this work. Re: Do I have to empty pool for landscaping around it? 2Feb 17, 2016 4:11 pm This question is a few months old now, so you may have already finished the job, but I would have suggested that you contact your local shire for advise, although most likely, you would have to drain the pool. However, if you were able to cover it, that may suffice. Thanks again Simeon for being so elaborate. Appreciate it. Its gives us a very idea. Kind Regards 4 3665 There is evidence of water on the head reveals. That could have happened during the build, or may be happening currently. There are water stains above a couple of windows… 2 3830 You’re on the right track, wire brush in a grinder then a zinc rich epoxy primer then a top coat of some sort, like a waterproofing membrane. Raising the concrete would… 1 7030 |
