Browse Forums Pools & Spas 1 Aug 14, 2015 12:05 pm hi I installed a spa on second storey, while the builder put the pump on the external wall. I understand this is normal practice. But it looks ugly. Could it be installed indoor? I think I can find a place under the washing basin. Then only problem is I don't know how much the noise will be, as I was told the pump will have loud noise. If the noise is acceptable, I would like to move the pump indoor. We were lucky in that our old house was so small (86 square metres) compared to the new house, they were able to take enough readings around the old backyard house before… 8 37150 Hi, We have a single story MacDonald Jones house, on a waffle pod slab with steel frame. Are we able to build a second story extension? Other info is we are 900mm from… 0 8484 We are building a second dwelling and are currently selecting window and door frames. We want to blend into the forest and also bring out the stone work and the fake wood… 0 15938 |
