Browse Forums Pools & Spas 1 Jun 28, 2015 12:01 am Hi there pool gurus. I have planned to install a fiberglass pool from the beginning of my build planning. I got the pre-installed pipe works through retaining wall correct but Unfortunately I miss read plans and rather than the area where the pool being filled with clean fill when the sand pad went in, I have been left with a large hole. (Plans said only 300mm fill above NGL which is what i got) I now have very limited access to bring in bulk fill, it can be done but will have to be brought in with a bobcat. My question is, am i best bringing in the fill, then pool company digs it back out again, (I can use it else where on the block) or will the pool company place the pool in and then backfill around the pool? Either way I will seek advice from pool company, but that is probably a year or so off. I just wondered what thoughts may be out there in the meantime. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Fiberglass pool instal 2Jun 29, 2015 10:50 am Yeah - check with them. I have a feeling they back-filled - but after the hole was dug of course. Good idea though to use good fill - to re-use later. They can charge for taking away what they dig out ... We were quite lucky - vacant blocks either side. Hi everyone, Looking for some advise. We are about to build an above ground pool in our backyard. There is a private sewer line running under the pool at 1.6m… 0 11763 Hi, I'm new to this forum so I hope I'm doing this post correctly. Please advise if it's not. I've just bought my place. The inground pool has a marble lining that has… 0 13665 Murraya could be a great option for you. It creates a great tall screening hedge but doesn't drop fruit like lily pilly. The flowers smell divine. 2 10267 |
