Browse Forums Pools & Spas Re: any realestaste agents around? whats better concrete or 6Apr 04, 2015 7:04 am i have a robot cleaner for my pool they are fantastic and keep the pool clean. and during winter i have a pool blanket as well. i have also just installed a solar pool heater. Grab a hose, insert it at the top of the inlet/down pipe and turn the water on and see where the water is escaping from. Then you'll know. 3 8488 brokers will also be in a position to get you a better rate than the advertised rate most times. 6 7584 Bigger the better for storage for me IMO. But I guess it's harder to tell the cost/benefit in your example - mainly the 'cost'? If you go 700mm, what are you doing extra… 2 1244 |
