Browse Forums Pools & Spas 1 Jan 04, 2015 4:13 pm Gday All, Im always the one for asking weird and wonderful questions about DIY stuff, I've often pondered for hours then thought hopefully some one has been in my boat and thought of doing it a better and simpler way! I have a spa 2150mm x 2150mm that i need to lower into a 3200mm x 3200mm hole in the backyard which is 700mm deep. We can get the spa up to the hole in the backyard but I'm stuck from there. It weighs 450kg. Here is my dilemma…. *No access for a crane (spa will be brought in on its side down the side of the house) , can't get access thru neighbours house. *Dont want to cantilever it into the hole (don't want to damage it, let alone hurt or crush anyone in the process.) Dont want to use 6 strong men to lift it the hole or use ropes, someone always gets hurt. Looking for a safe way ! Someone must have done something like this in their previous life… Im happy to hire or buy something to assist me, money isn't an issue Thinking caps on guys!!!! Any help appreciated Never argue with an idiot. They will only bring you down to their level and beat you with experience. George Carlin Re: Lowering spa into hole 2Jan 04, 2015 5:11 pm A portable gantry crane like this would be one way. http://www.redfernflinncranes.com.au/gantry-cranes. The other way would be to put planks over the hole. set the spa to the correct location on the planks. Use a pulley on a tripod or beam between scaffolding and 1. lift the spa 2. remove planks 3. Lower spa into position The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Lowering spa into hole 3Jan 04, 2015 6:04 pm Thanks Brian, You seem to be answering a lot of my weird and wonderful questions lately! This definitely looks like the solution, any idea what they cost to hire? Never argue with an idiot. They will only bring you down to their level and beat you with experience. George Carlin Re: Lowering spa into hole 4Jan 04, 2015 6:44 pm Over the years I have had to get a lot of large heavy gear into and out of sewers! Sorry I can't give you an idea of price as I have been out of that business for quite a few years. The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Lowering spa into hole 6May 10, 2015 6:14 pm A mini crane like this is available as narrow as 1100mm or a gantry as pictured available nationally from kenards lift & shift centres . Cost vardys depending on beam length required . Apx daily cost $300 Thanks for your advice. So far i have not noticed any issues with doors and windows. Builder advised they will organise drainers to inspect 2 weeks ago but no further… 7 18792 can’t tell from the photo, a tie down rod will be 12mm, is it a steel beam? he should be able to work it out 1 4462 3 3561 |
