Question re temporary fencing
Hoping someone can answer my question! We are putting in a fibreglass pool before our house is handed over. We are told that we will have to wait a few weeks before paving can go in (because of settlement?) and therefore we can't put our permanent fence up straight away. We're told therefore that we need temporary fencing.
I was wondering if anyone knows if it is permissible to cover the pool up (with planks??) rather than fence it? This would allow other contractors more straight forward access while work goes on.
If it is permissible does anyone know where I can source temporary cover in Perth and if its more expensive than temp fencing?
Thanks everyone!
Maggoe
Thanks very much for the replies.
I really like the idea of doing it ourselves with structural pine and plywood. Our pool is very small, so this should be very doable (only 4.2 X 2.6). If you're in Perth Robbie I don't suppose you still have ply sheets to sell??
Mgilla I was thinking about that - can you see an issue with filling the pool etc but then just popping the hard cover on top?
Thanks very much for taking the time to respond!
Maggie.
I love giving my Urban Myths thread a plug (see it is still going) but ... viewtopic.php?f=1&t=62127&p=1247685#p1247685 ... you can have issues with FG shells in the ground with no water in them.
Can you see an issue with filling the pool with water and then popping lid on top?
Cheap & effective
Best to make it strong enough for somone to walk on
Hi Mike - that is some thread! Must have a proper read!
In a word, ... no ...
I'd probably tip in a bottle of that chlorine stuff - the pool shop has.
1
Hi JW I just read your post and I find this situation quite strange. When we build, we get a temp pole for construction which becomes the permanent pole for one of the…
30/09/2023
Hi all, Not sure if this is a good place for this question but I guess we'll find out! I'm a novice, building a modular room inside my garage/shed and need to create…
25/09/2023
Need to remove glass panel out of concrete without wrecking the glass to get the spa room in, any recommendations on how to do that. Thank you
