Browse Forums Pools & Spas 1 Jun 19, 2014 7:11 pm We are going to knock down and rebuild and have been getting quotes for demolition. The demo guys are suggesting that if we want a lower quote we could empty the pool ourselves. Just wondering how easy our hard it is to do so? And if it's not something we could do ourselves then where could I go to get quotes? Would pool shops empty pools? TIA Re: Draining a pool 2Jun 19, 2014 7:41 pm If you are going to demolish the pool its not as critical a job as it is if you intend the use the pool again You can buy a basic electrical submersible pump from a Local DIY warehouse for around $60 + as much hose as you need to get to a sewer discharge point. You shouldn't discharge chlorinated water to a drain and you should check with the sewerage authority if they have a a discharge limit. It could take between 12 and 24 hours to empty the pool. The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Draining a pool 3Jun 22, 2014 10:25 am Moomoocow We are going to knock down and rebuild and have been getting quotes for demolition. The demo guys are suggesting that if we want a lower quote we could empty the pool ourselves. Just wondering how easy our hard it is to do so? And if it's not something we could do ourselves then where could I go to get quotes? Would pool shops empty pools? TIA Can I ask how you let excess water out now ? Re: Draining a pool 4Jun 22, 2014 2:22 pm either buy or hire a submersible pump, unscrew the waste side of your filter and run the hose into there. Laws have changed as to where you can run your waste pool water, but if you use the resource that was provided and approved when the pool was build you should have no trouble. another is to get a 40mm hose and connect it to the inlet side of your existing pump and to the lowest point in the pool. Hi everyone, Looking for some advise. We are about to build an above ground pool in our backyard. There is a private sewer line running under the pool at 1.6m… 0 11760 Hi, I'm new to this forum so I hope I'm doing this post correctly. Please advise if it's not. I've just bought my place. The inground pool has a marble lining that has… 0 13663 Murraya could be a great option for you. It creates a great tall screening hedge but doesn't drop fruit like lily pilly. The flowers smell divine. 2 10248 |
