Browse Forums Pools & Spas 1 May 06, 2014 2:37 pm Hi All, We are considering a pool for our new home...the slab is already laid and the frame is up. I know there are rules in regards to the pool being the equivalent distance away as it is deep if the foundations have not been reinforced. Is this the same if we wanted to put it close to the alfresco? The alfresco was laid at same time as the main slab and is under roof. Thanks for you help. Re: Pool close to a house 2May 06, 2014 3:08 pm NZCarters Hi All, We are considering a pool for our new home...the slab is already laid and the frame is up. I know there are rules in regards to the pool being the equivalent distance away as it is deep if the foundations have not been reinforced. Is this the same if we wanted to put it close to the alfresco? The alfresco was laid at same time as the main slab and is under roof. Thanks for you help. Whoever is doing engineering for your pool will take care of that and there are various options of dealing with that including underpinning of the slab if required. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Pool close to a house 3May 10, 2014 2:26 pm as above...ask engineer Its diff for concrete and fiberglass. Re: Pool close to a house 4May 10, 2014 4:52 pm NZCarters Hi All, We are considering a pool for our new home...the slab is already laid and the frame is up. I know there are rules in regards to the pool being the equivalent distance away as it is deep if the foundations have not been reinforced. Is this the same if we wanted to put it close to the alfresco? The alfresco was laid at same time as the main slab and is under roof. Thanks for you help. The alfresco is part of your slab just with a step down usually.A engineer will have to determine the angle of repose for underpinning your slab sometimes quoted as 45 degrees in clay but is different in sand/silt.If the shallow end is closer to the slab then this may reduce the depth of your underpinning. Re: Pool close to a house 5May 13, 2014 7:25 am Don't like pools up against houses. But - that said - I'd also ask the builder what they think. Pool companies promise the world before the contract - then the world isn't in the contract. Surrey Hills, Vic 3127 Garage is being built with metal, 3m distance away from my cover deck. It is parallel to my cover deck, living room, family room and kitchen,… 0 9617 Hi everyone, Looking for some advise. We are about to build an above ground pool in our backyard. There is a private sewer line running under the pool at 1.6m… 0 11755 Hi, I'm new to this forum so I hope I'm doing this post correctly. Please advise if it's not. I've just bought my place. The inground pool has a marble lining that has… 0 13662 |
