Browse Forums Pools & Spas 1 Apr 30, 2014 8:19 pm Looking to sell my Cyclone Storm Sports Spa - Pearl Shadow which is about 4 years old and in perfect working order. It was purchased from the pool and spa shop in Edwardstown Reluctant sale due to building new house and not having space and facilities at the new house. currently drained and disconnect ready to be removed. technincal details can be found here http://www.cyclonespas.com.au/getfile.a ... ectID=2533 Adelaide pickup only reply on here or PM directly Andrew Hello I am developing 2 side by side units. Wish someone can help me on the following questions 1) Which stage should be the storm water pipe installed during the new… 0 7827 If you need to be able to access these then you may need to dig them out and cut them so you can add a socket and a riser to the required height. We normally add a… 1 6854 Thanks for that, the PVC pipe is still about 40cm below ground level and it sticks out of the sand with no end cap or anything on it just open pipe, is this the finished… 2 10484 |
