Browse Forums Pools & Spas 1 Apr 17, 2013 11:26 am We've just had our pump etc put in place and we had originally considered getting a custom made aluminum slat box made to fit over but now we are wondering if the $2k'ish price tag is worth it. We have also been let down a bit with positioning of the electrical and also the pump/filter, as we'd made it clear we were having the area liquid limestoned and the installer has placed the pump and filter on a slab above the level the limestone will be poured at. Also the proximity to the side fence makes us doubt a box will fit in between. You can see here where the pump etc is in relation to the pool Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Equipment here; Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ We know of a good brickie and we are now thinking of putting a rendered brick wall from the side fence, then turning into the back wall and leaving a gap big enough to walk in and also store other equipment etc. Obviously there'd be no top on it but i don't think that is an issue??? Similar to this; Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Anyone have any other ideas or have similar to what we are thinking that could share pics??? Building the Riva by Dale Alcock Homes. Follow our progress here: https://forum.homeone.com.au/viewtopic.php?t=57075 Re: Hiding pool equipment - ideas please?? 2Apr 17, 2013 6:00 pm hi at one stage i was thinking of this http://www.clarkrubber.com.au/diy-store ... ution.html i asked the store guy and he said a pump can fit quite comfortable and they do have other sizes i was also thinking of a small colorbond storage to fit but am still looking into ideas as pump and filter will not be installed for another month you have a very nice pool very similar to ours Re: Hiding pool equipment - ideas please?? 3Apr 17, 2013 8:14 pm Hi em. 2 options. 1 build a colourbond shed same colour as fence this will make it almost invisible . I also like to allow enough storage space for cleaning equipment, kits toys & a high shelf for chemicals . See 1st pic Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Another option is to make it a feature using timber or stone like these Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ As for the limestone the equipment is just on a concrete paver . You can simply disconnect pump, filter, chlorinator & get the limestone done around pipes then re connect. Put a packer under them or adjust pipes if required Cheers Re: Hiding pool equipment - ideas please?? 4Apr 18, 2013 8:37 pm Thanks for the ideas!! We have spoken with our brickie and he is going to build us a wall around it leaving a small gap on the retaining wall side to get in. He also suggested cladding the front as opposed to render and using our left over bullnose headers from the pool to go on top to tie in with the pool. Building the Riva by Dale Alcock Homes. Follow our progress here: https://forum.homeone.com.au/viewtopic.php?t=57075 Re: Hiding pool equipment - ideas please?? 5Apr 24, 2013 1:31 pm Just an idea - but the equipment you have can be installed in a line - maximum width of the ZX cartridge only 400mm (pump is 250mm)- you only have suction and return line - it should have been installed down the side of the house (the churn and burn fibreglass guys tend to just plonk it within 6m of the pool) 4 lengths of 40mm CLASS 9 pipe , some elbows and pvc pressure glue - and tuck it around the corner (or get pool shop or reputable pool man (are you in perth?)) to move it - 2hrs x $88 plus about $80 pipe and fittings. Sparky to move points (probably where the conduit runs from back of house anyways) may cost $300? Pretty cheap compared to a corner cover that forever looks out of place. Just an idea Re: Hiding pool equipment - ideas please?? 6Apr 24, 2013 4:24 pm Hi supernicko thanks for the suggestion but unfortunately we have no room at the back of the house which is only 1.5 max from the boundary retaining wall so we need all the room out there as it is. We are happy with the location and hiding with a cladded brick wall, pretty sure it will come up nice Building the Riva by Dale Alcock Homes. Follow our progress here: https://forum.homeone.com.au/viewtopic.php?t=57075 Re: Hiding pool equipment - ideas please?? 7Jul 25, 2014 3:54 pm Sorry to bring up an old thread, but has anyone enclosed their pool filter who also has a gas heat installed? The gas unit sits next to the filter. I was thinking of getting a timber box made up for the filter and just cutting holes for the returns to the gas unit? Re: Hiding pool equipment - ideas please?? 8Jul 28, 2014 11:14 am We are looking at this. Our equipment is quite long and high - we have self cleaning and chlorinator etc. We decided on a beam on wall - with a colour bond roof off it. The costs from different people were unbelievable. Re: Hiding pool equipment - ideas please?? 9Jul 28, 2014 11:15 am sco77k Sorry to bring up an old thread, but has anyone enclosed their pool filter who also has a gas heat installed? The gas unit sits next to the filter. I was thinking of getting a timber box made up for the filter and just cutting holes for the returns to the gas unit? Ours also has a heater. So its long and we needed room above to get cartridges out of self cleaners. I would say both styles you have pictured are steel. The lower chord of the first pic would be a massive lump if made using timber considering the size of the rafters. If… 1 6436 Hi guys We have just removed a very large grape vine which was mounted to a structure along this wall. This is a shared wall with our neighbour, and after removal, we… 0 4086 |
