Browse Forums Pools & Spas 1 Mar 25, 2013 5:59 pm Im sorry iv search everywhere i can find, but when building a pool in say shire of yarra ranges victoria... does the pool need to be setback from the boundary a certain distance? Ideally i would want to have it at approx 300mm-1m of the rear boundary, and then within 750mm of a house wall. but i cant find anything on if that's allowed all not, just a whole bunch of trash on IT MUST BE FENCED!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! ... Re: Pool setbacks 2Apr 26, 2013 12:45 am Hi, I cant help too much as I am in SA but my local council have a 600mm rule from a neighbouring fence. Might pay to give your local council a call to see what their requirement are, as their requirement will be AT MINIMUM "the pool rules" plus some. Good luck, and please post your findings. Cheers Andrew Re: Pool setbacks 3Apr 26, 2013 6:21 pm Setback from side boundary is 1m . You can get closer with a planning permit but is no guarantee of approval . Pool can be butted up against the house subject to engineering not council regulations. Cheers My land is 260m2 (10m x 26m) located in claymore NSW. Under campbelltown council. I know in general the following setbacks would apply ground floor side setback =… 0 4175 In addition to protecting your children, glass pool fencing has the benefit of being simple to clean and maintain. You probably won't need anything more expensive or… 0 3038 Hi everyone, Looking for some advise. We are about to build an above ground pool in our backyard. There is a private sewer line running under the pool at 1.6m… 0 7642 |
