Browse Forums Pools & Spas 1 Aug 02, 2012 4:05 pm I am interested in a property where the backyard is on a slope with the high side of the slope on the right of the backyard and sloping towards the left (facing the backyard). If i do go ahead with the property, do you have an advise or issues you may see with constructing a pool on a slope? New to the property market so any advise will be really appreciated thanks, John Re: Inground pool on a slope 2Aug 02, 2012 5:55 pm john1980 I am interested in a property where the backyard is on a slope with the high side of the slope on the right of the backyard and sloping towards the left (facing the backyard). If i do go ahead with the property, do you have an advise or issues you may see with constructing a pool on a slope? New to the property market so any advise will be really appreciated thanks, John We had a similar slope but also sloping downwards from the house as well. Our solution was to build the pool in the left with the bottom left corner about 1.5 out of the ground. We then used the excavated material to as fill to level the area and slope down the hugh sides. From a cost viewpoint the pool builder said no real difference as more reinforcent is offset by less excavation. Inground pool on a slope 3Aug 02, 2012 8:08 pm Sloping blocks offer lots of landscaping opportunities but can also be very expensive. Using the out of ground as a feature or a infinity edge looks great. How big is the block & what is the fall? . If it is acreage can you use excavated dirt to batter down on the low side this is the cheapest option. You can retain it or leave pool out of ground & deck around it. What size pool are you looking at? Cheers andrew A survey must’ve completed by a certified surveyor. This form part of every DA requirement 3 223632 Need advice on the backyard plan above. Should I excavate and cut all of the dirt to level with the house slab or semi-excavate as per photo above? Both left and right… 0 24873 Hi All, We have recently purchased a sloping block (3.5m fall building envelope, 6m overall). Just wondering if you know of any good builders that you would recommend for… 0 1776 |
