Browse Forums Pools & Spas Inground pool on a slope 3Aug 02, 2012 8:08 pm Sloping blocks offer lots of landscaping opportunities but can also be very expensive. Using the out of ground as a feature or a infinity edge looks great. How big is the block & what is the fall? . If it is acreage can you use excavated dirt to batter down on the low side this is the cheapest option. You can retain it or leave pool out of ground & deck around it. What size pool are you looking at? Cheers andrew A survey must’ve completed by a certified surveyor. This form part of every DA requirement 3 223588 Need advice on the backyard plan above. Should I excavate and cut all of the dirt to level with the house slab or semi-excavate as per photo above? Both left and right… 0 24832 Hi All, We have recently purchased a sloping block (3.5m fall building envelope, 6m overall). Just wondering if you know of any good builders that you would recommend for… 0 1752 |
