Browse Forums Pools & Spas 1 Jul 06, 2012 3:12 pm Hi All We are having a concrete pool constructed at the moment. The concrete was poured two weeks ago. I have noticed that there is a leak in the concrete and water/red dirt is seeping through into the empty pool. The pool guy did find a water spring in our backyard whilst digging. My question is, what is the best way to fix this?? Is this something that will be fixed when they add the pebblecrete?? I would of thought that it would be best to fix this before going any further into the construction. Re: Concrete leak during construction 2Jul 06, 2012 3:58 pm If your new concrete pool is leaking from the outside in you could be having serious problems because it is the concrete shell that is supposed to be waterproof. Have you got any pics? Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Concrete leak during construction 3Jul 06, 2012 4:44 pm http://imageshack.us/photo/my-images/83 ... 265uj.jpg/ Unfortunately it has just rained but you can see the seepage running down from steps toward the drain. Thanks for your help. DIY, Home Maintenance & Repair Are you doing this with a building permit? Conversion of a non habitable room into a habitable room requires building permit. 3 17322 Hello needing some advice. I was about to build my Alfresco and needed a new slab and remove exisiting slab as its not standard. So they start to excavate and jackhammer… 0 10701 1 62024 |
