Browse Forums Pools & Spas Re: Pouring concrete in the rain 2May 17, 2012 2:05 pm depends on the amount of the rain, if its not much rain then it wont make a difference, if they were doing concrete with a smooth finish it would pit in the rain but the rough pool wont be impacted, and given you will put tiles or something on it, there will be no impact. If you are talking about flooding rains and having a foot of water at the bottom of the pool then you might have a problem Building NBG Buckingham 46 on Property in rural Victoria my Building Thread viewtopic.php?f=31&t=46837 Re: Pouring concrete in the rain 3May 17, 2012 5:07 pm kerfuffle Hi All Our pool provider poured concrete in the rain. Will this weaken the pool or cause any defects? The surface is currently quite rough. The final coat hasn't gone on - this is just the concrete shell. Thanks K Asd long as it wasn't so heavy the top part of the pool washed down to the bottom, the fact the concrete stays wet longer means it will have more a positive affect than negitive. Don't be concerned with how rough the finish is, just gives the pebbles or what ever coating your having something to stick too. Hi, does anyone have any experience with using Trex rain escape or EPDM rubber to waterproof a deck so you have dry space underneath. Popular in the US and realize that… 0 3451 Yes you are correct, unless there are outside works which form part of the contract such as landscaping or driveways, and importantly, the work delayed is on the critical… 1 3535 Hi When it rains in a particular direction water comes through the security door. It hits the main door and the bottom swells and jams. There is already a cover over the… 0 38448 |
