Hi everyone,
Has or does anyone use a pool heatpump how did you feel iy worked and what were the running costs like i am looking at a 8-12 kw unit either single or 3 phase
Browse Forums Pools & Spas 1 Jan 29, 2012 8:16 am Hi everyone, Has or does anyone use a pool heatpump how did you feel iy worked and what were the running costs like i am looking at a 8-12 kw unit either single or 3 phase Re: heat pump 2Jan 29, 2012 5:39 pm i have used them on a number of jobs & locations. .it is very hard to compare different brands as they are rated at different ambient temps. i have once trialled a 9kw & a 16 kw connected to the same pool. the 9 heated it faster & warmer. don't believe the bs brochures if pool is less than 12k a gas unit is much more efficient heats pool in a fraction of the time of a heat pump. if pool is outdoors & roof space is available a 200 percent solar system could be a better option. what size & depth pool do you have. do you want it to heat pool in winter. will you be using a cover cheers andrew Re: heat pump 3Jan 30, 2012 8:39 am Thanks , Pool is 22000 ltr 1200 actual water depth and i would like to use it all year round my wife works for a major pump importer so getting some quotes from overseas so just need to figure out what size unit to get i also have 3 phase power if i need a big unit and i will have a cover .. Solar blanket for summer and hopefully a dedicated pool cover for winter. pool in a liner type but fully inground Cheers Dean Re: heat pump 4Jan 30, 2012 5:31 pm the minimum size you would require is a 16kw . this will take apx 48hrs to get pool from 2o to 3o degrees with a average ambient temp of 18deg. other end of the scale a 4o kw 3 ph unit will heat in same conditions in about 12 hrs these estimates are based on nothing but experience when checking specs look for testing temp for water & ambient at 2o deg. look for cop of 5 plus i used a 6okw unit on a 12m lap pool in melbourne which heats in about 14 hrs without a cover the biggest problem is the cost of the heat pump but maybe you can get one for the right price. hope this helps Re: heat pump 5Jan 31, 2012 8:43 am Thanks will keep all this in mind i did have a chance to purchase a bowman electric pool heater 30 KW but nearly fell over when looked at specs 42 amps per phase current draw. Cheers dean There may be answers here but can't find anything. I have a closed in veranda, four windows. North facing, just had sunblock blinds installed. A bit cooler (actually… 0 2983 |
