Browse Forums Pools & Spas 1 Nov 29, 2011 7:13 pm I'm installing a sunsoka braceless above ground pool from clark rubber, i want to put it about 80cm in ground. I have an excavator coming to dig the whole but as i havent got the pool or instructions i don't know how much room i will need around the pool for installation, the pool is 6.2 x 3.8 does anyone know what width and length the hole would need to be for comfortable installation, bearing in mind that the bigger the hole the bigger the cost. any opinions would be apreciated,thanks Re: installing sunsoka above ground pool semi in ground 2Dec 15, 2011 8:27 pm I would call into clark rubber and ask for a copy of the install manual. Re: installing sunsoka above ground pool semi in ground 3Dec 18, 2011 2:25 pm i would ask at clark rubber we found them very helpful went we bought a a/g pool from someone everything was in the boxes but council wanted a copy and pics of the pump and ladder etc. finished building 40 square home on 5 acres with perry homes.working on the landscaping just finished pool deck with ://forum.homeone.com.au/viewtopic.php?f=31&t=2217 Re: installing sunsoka above ground pool semi in ground 4Oct 16, 2012 10:10 pm Hi. I'm researching about the best type of pool is best for my budget and wanted to know how you went with the semi inground installation of your pool and if your happy with the pool itself? Hi everyone, Looking for some advise. We are about to build an above ground pool in our backyard. There is a private sewer line running under the pool at 1.6m… 0 11917 Hi I live in a 100yr old semi and my neighbour added an additional floor last yr and our architect has advised that we can knock down our semi and build a free-standing… 0 37821 Hi, Seeking volume or semi-custom builder in victoria(east), which have existing double story wide floor plans. Seeking 18-20m wide homes with depth of 12-15m long. Or… 0 25297 |
