Browse Forums Pools & Spas 1 Oct 03, 2011 1:38 pm We are building a house next to a large reserve in Melbourne. Some big gum trees are close to our house and we plan to put in a pool but are worried about debris/leaves etc. We thought about in an indoor pool but have been told it would add ca 100K to the cost of the house. An alternative would be to put a roof over the pool (in effect putting it under an extension of the verandah), partly to help keep it clean and partly to give sun shade. Has anyone done anything similar and does it actually help? Hi everyone, Looking for some advise. We are about to build an above ground pool in our backyard. There is a private sewer line running under the pool at 1.6m… 0 12052 Cheers. The painted render is a bit chalky to the touch. To prepare the surface for best adhesion, what would you recommend? Also, given that there must be some… 6 9451 Much a do about nothing. You can see the fall heading to the actual drains. Stormwater ingress will be minimal and it's far better to have the top sitting flush rather… 12 6345 |
