concrete swimming pool
Page 1 of 2
I have posted b4 regarding a concrete swimming poll using an ADBRIMASONRY system used in Queensland for a number of years. I wanted to ask some concreters if i could build it a different way.
Pour concrete pool base approx 180 mm thick using required rebar etc and then form up the walls and pour separately my question is are there any sealers available to seal walls to base before painting or tiling. My main reason for doing was to save the cost of purchasing the bricks for the walls that are required for the other method of construction. as forming the walls will take a bit more time.
Thanks
installed.
...not a 'control joint'
Unsure why swimming pools are so different, we have 2 6 mtr x 6mtr process water tanks at work these were poured on concrete bases with 200mm thick walls and hold 50,000 litres of water each have been there for 10 years and never leaked just wanted to apply the same principal to a pool. as a very cost effective construction.
jointing compound.. concentrating on the inside of the vessel.
If it was 200mm thick then sealing it would be aesthetic only, so depending on the
water treatment, chlor or salt choose a coating to suit you use.
But a 200mm wall of conc is a lot of conc.
I wonder what the cost to construct the work tank was.. any idea? what year was it made.
looking at a 7x3.5 with an average 1.5 wall height required concrete with 200 mm thickness all the way around 12mtrs @175 for 32mpa =$2100
plus rebar $1200 and time to do formwork????.
A construction joint for floor/wall ... then rake(open) the joint and chalk with a flexible
Had a look at drawings walls and floor are 350mm thick 40 mpa concrete with 2 rows of 12 mm rebar in each wall and floor bit of an over kill for my pool but will apply a similar process just on a smaller scale if engineer OK.
The link is a forum that I have been a member of for 4 years.
The thread is a set of fish tanks that I made a few years ago...
You will need to scroll down a bit.
http://www.backyardaquaponics.com/forum ... +waterfall
This is what it looks like May 10
http://www.backyardaquaponics.com/forum ... 93#p230493
Sorry for the gratuitous advertizing
The form was floating.
Maybe look at Kryton or xypex.
Basf chemical constructions would have something for sealing the walls.
Also look at a product called Dincel to build the walls. they may have engineers to sign off on the plans.
Hoping to build a pool in a similar fashion as you have specified.
What are you using to seal the concrete slab?
Good luck
Pulpo
They don't leak!.
if slab poured first see previous post Hydratite or hydro seal BR these go in between slab and wall pours.
I spoke with a few formwork people most dont want to help and just recommend shotcrete was quoted $3200 for shotecrete hire for min 15 cubic meters and concrete cost on top which is $240 meter and will require approx 10 i can build whole pool for a little more using versaloc bricks or forming walls and pouring. just need someone to help with formwork ie building an internal wall 7x3.5 meters and then suspending above ground and reo at 150 mm and pouring concrete. As per ponds on previous post structure should be fine but most people dont like going outside the square.
I think a wall of concrete 200mm thick for a swimming pool is considerable.
Although they have a smaller thickness wall also which I may also work.
Especially when compared to water tanks.
I'm always incline to add more steel; for steel look at steelforce.
You could also use icf insulated concrete foam.
I know thermacell show swimming pools built this way and have seen them.
Although not my choice.
Good Luck
Pulpo
2
The last home I lived in didn't have a pool and when i went to sell it the agents were not happy, even telling me to put one in to sell the place. The agents weren't happy…
