Browse Forums Pools & Spas 1 Oct 07, 2010 12:50 pm I just bought an Intex 10ft round above ground pool that has a small pump & cover (super bargain @ KMart for $48) Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Does anyone know if these things require any sort of chemicals, or does the filter do all the work? Next trick will be finding some level ground to put it on!! Re: Intex Above Ground Pools - Chemicals or not? 3Oct 07, 2010 8:23 pm We had one last summer, 14 foot. It definately needs chemicals. We found we had to add chlorine pretty much daily. We brought a cheap test kit from bunnings to test the chlorine and pH. Sonya Re: Intex Above Ground Pools - Chemicals or not? 4Oct 08, 2010 11:50 am Be aware of any pool fencing regualtions, I don't know about SA in Qld esp they are getting tougher. Cheers Lou http://take2-customdesigndownslope.blogspot.com 07-10-09 omg they have cut the block 14-05-10 we finally have the keys Re: Intex Above Ground Pools - Chemicals or not? 5Oct 08, 2010 9:37 pm You will definitely need to comply with pool safety regulations. Also, if you have water restrictions in your area, you will probably not be able to fill it up from the tap (either not at all or you will need a permit). Hi everyone, Looking for some advise. We are about to build an above ground pool in our backyard. There is a private sewer line running under the pool at 1.6m… 0 11760 6 4348 Hi, I'm new to this forum so I hope I'm doing this post correctly. Please advise if it's not. I've just bought my place. The inground pool has a marble lining that has… 0 13663 |
