Browse Forums Pools & Spas 1 Feb 23, 2010 2:22 pm Hello all My house is positioned to take up the entire width of the block (11mtr frontage) and would not be able to get a bobcat or dingo into the space where I want a pool (due to retaining wall). I am looking at my options towards an above ground concrete pool; the size would be 4mt wide by 3mt long. The styles that I have seen so far look great but am a bit stumped on the following:- 1. Would an above ground pool be cheaper than a below ground? Presuming no digging would mean yes but not knowing if the structure needs to be stronger I’m not 100% 2. Are there any allowances to be made for going above ground? 3. Should the $1250/lineal meter rough cost apply? I would go straight to a pool company to ask these questions but I am not living in the Perth at the moment and the build is just in the slab for stage. Thanks to anyone for their insight. Re: above ground concrete pool 2Feb 23, 2010 3:26 pm Will be more expensive due to more concrete, more steel and needs to be formed up with timber. Landscape Design & Construction http://cherub.squarespace.com/ Re: above ground concrete pool 4Feb 24, 2010 8:42 am Would paying for a hand dig be a possibility. I would imagine with decreased lot sizes, there would be other's that would have been in your situation. I would ring a few pool companies with the dimensions of your back yard and see what they say. Cheers jbarry My build thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=25713 13th Oct - Offer on block 4th Dec - Settlement of block scheduled (delayed due to titles) 22nd Feb - Titles Issued 17th Mar - Land Settlement 17th Mar - Pre-start meeting Re: above ground concrete pool 5Feb 24, 2010 3:17 pm jbarry Would paying for a hand dig be a possibility. I would imagine with decreased lot sizes, there would be other's that would have been in your situation. I would ring a few pool companies with the dimensions of your back yard and see what they say. Cheers I did some ringing this morning, I was surprised with the outcome. Fiberglass is a possibility, the company said they can frestand as long as the support was there for any protrusions. They can put a dingo through an opening and they will build a ramp to gain access from there or worst case they can hand dig (would be a pain of a job). I have found some fiberglass models that are the exact size I was after and have a rough idea of the price, when I am back in perth I will do some concrete pool shopping too. Re: above ground concrete pool 6Feb 24, 2010 3:37 pm Hi There If you do want to go fibreglass, I really recommend you pm "Michelle From Perth" for her experience with a pool group she had dealings with. Her information was invaluable for us in helping make our decision with our pool - confirming some of our fears that just didn't sit right with two companies we received quotes from. Just be careful of hidden costs that they aren't always upfront with. Have a look at this thread for further info: viewtopic.php?f=17&t=28932 Good luck. jbarry My build thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=25713 13th Oct - Offer on block 4th Dec - Settlement of block scheduled (delayed due to titles) 22nd Feb - Titles Issued 17th Mar - Land Settlement 17th Mar - Pre-start meeting Re: above ground concrete pool 7Mar 31, 2010 6:40 pm Dane83 Hello all My house is positioned to take up the entire width of the block (11mtr frontage) and would not be able to get a bobcat or dingo into the space where I want a pool (due to retaining wall). I am looking at my options towards an above ground concrete pool; the size would be 4mt wide by 3mt long. The styles that I have seen so far look great but am a bit stumped on the following:- 1. Would an above ground pool be cheaper than a below ground? Presuming no digging would mean yes but not knowing if the structure needs to be stronger I’m not 100% 2. Are there any allowances to be made for going above ground? 3. Should the $1250/lineal meter rough cost apply? I would go straight to a pool company to ask these questions but I am not living in the Perth at the moment and the build is just in the slab for stage. Thanks to anyone for their insight. Often they can crane a small excavator into the site. So in ground may be possible Re: above ground concrete pool 8Mar 31, 2010 7:13 pm 700kg excavator with expandable tracks will fit thru a standard 820mm door opening and dig down app. 2 mtrs in depth. Conveyour belts for excavated soil will get rid of the need for a second machine in backyard. Concrete gets pumped in so no need for access for a conc. truck. Da Vinci Outdoor Living Architectural landscaping http://www.davincioutdoor.com Re: above ground concrete pool 9May 17, 2010 4:01 pm It might sound a bit crazy but would there be any access from any neighbour around your block? They might have better access and only a timber fence that could be taken down for the time being and then put back up... If there is no access whatsoever to get a backhoe or bobcat in, how do you poor the concrete??? Or how do you get the steel/timber delivered? Carried through your front door?? I'm tyring to work out how you'd do it... Re: above ground concrete pool 10May 20, 2010 12:21 pm Island OB It might sound a bit crazy but would there be any access from any neighbour around your block? They might have better access and only a timber fence that could be taken down for the time being and then put back up... If there is no access whatsoever to get a backhoe or bobcat in, how do you poor the concrete??? Or how do you get the steel/timber delivered? Carried through your front door?? I'm tyring to work out how you'd do it... The place I am building is completely built already, I am the last block that is vacant. I have a unit complex behind me and would get access through my neighbours properties. I have spoke to a pool supplier and they advised that they can fit a fiberglass pool in by craning it over the top of the house. I can fit a concrete pool in, they would pump the concrete down the side of my property. Once the house is complete I will decide on which option is best for me. Re: above ground concrete pool 11Jul 11, 2010 9:27 pm HI there have a look at ADBRI MASONRY website they have concrete versalock brick pools which can be built above ground and then the walls are filled with concrete to enginners specs as we llas floor they have some basic drawings on their website which have been used in Queensland for over 15 years. Hi everyone, Looking for some advise. We are about to build an above ground pool in our backyard. There is a private sewer line running under the pool at 1.6m… 0 11731 Hi, I'm new to this forum so I hope I'm doing this post correctly. Please advise if it's not. I've just bought my place. The inground pool has a marble lining that has… 0 13636 |
