Browse Forums Pools & Spas 1 Feb 08, 2010 12:50 pm Hi Folks, sorry if this has come up before, I wanted to know if a pool could be put in when it encroaches on a setback? It is a council setback requirement of 5 metres in our back yard. It isn't an easement. That is also there but the stormwater and sewerage pipes are on a 3m easement but the council has stipulated a total 5 metre setback. I want to use some of that 2m between the easement and setback for one side of the pool. Anybody come across this? Would council allow that sort of an encroachment? Thanks. SK Build thread: viewtopic.php?f=31&t=34120 Handover 23 Dec 11 Squatting 21 Dec 11 Fixed 12 Oct 11 Plastered 31 Aug 2011 Framed 7 June 2011 Site Start 7 Feb 2011 Land Titled 18 Jan 2010 Land Deposit 25 Jun 2009 Re: Pool encroaching on a setback? Would the council approve? 2Feb 08, 2010 4:35 pm Your council will have separate regulations about pools and the distance they may be from side boundaries. It probably varies a bit, so check their website, or give them a call. This was on google. Development controls 2.3.1 Front setback D1 New buildings within residential areas shall adhere to a front building line, which is 5.5-6m to the… 1 3640 Hi All, see above image. The required setback from the rear boundary in my case is 5m, as you can see the shape of the site and location of the boundary is slightly… 0 8431 Thanks Draftroom that definitely helps a heap. We are still at the very early stage of planning to see what kind of house would fit on our plot. While we are on a… 3 15712 |
