Browse Forums Pools & Spas 1 Nov 28, 2024 10:17 am Hi, our pool was laid with pebblecrete yesterday and acid washed today. However, the certifier is fully booked and can only come in next Tuesday to inspect and certify the fencing (ie 6 days after the pebblecrete was laid). This means that we are not allowed to fill up the pool until then. Will there be any problems with the pebblecrete exposed without any water for this long? Any advice is appreciated. If the cracks are in a reinforced slab you can use a tiling mat but from what I can see you would be better with a reinforced screed bed on a plastic slip sheet. This slab… 2 7914 Versaloc is a mortarless besser block system that still needs a properly engineered footing. If you just do a 400x200 footing it will fail in time. At 17m long you need it… 1 38039 Construction started in the first week of August, and already done the frame. It has started to move finally 8 14702 |
