Browse Forums Pools & Spas 1 Oct 05, 2024 4:34 pm Hello, I ordered a spa and it’s coming in 2 weeks, but recently realised that I need to prepare the floor to get it perfectly level? I wasn’t bothered as it was pebble exposed finish concrete slab, but as you can see from the photo it has quite steep slope. 70mm difference in 3.5m. What will be the most easiest and budget friendly option I can do? I was thinking about pouring self levelling compound but 70mm is way too thick for it I guess? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ What is going to go in that corner when the floor is filled in? Take that info to a qualified engineer and ask them re the proper procedure/material. 2 12749 I have an old spa in my bathroom which I was once told was a Lanark Rose 1810. The plastic on the jets is falling apart. The spa is raised up on a timber frame and tiled… 0 6693 bec of more thickness and underlay i prefer laminate. also my builder covers laminate only. 2 14255 |
