Browse Forums Pools & Spas 1 Dec 15, 2022 9:11 am Hi Brains Trust, My parents have bought a house that has a pool which is causing them some grief (possible leak) and they're also not using it. Mum's thought is to drain the pool and put some decking over the top so it's effectively just the existing surrounding decking with the pool covered up in the middle. Aside from the specific questions around draining the pool which I've seen covered here already. What are the points that she should consider? Is leaving a pool empty for a period of time feasible, or does that cause problems for future use? Thanks all, Dim Re: Decommissioning pool? 2Dec 15, 2022 2:16 pm if she needs to decommission pool it needs to be done correctly it will either become a boat and float out of the ground or it will fill with stagnant muddy water and stink cheapest option is probably to have leak repaired Re: Decommissioning pool? 3Dec 15, 2022 2:23 pm Thanks - that's really helpful, and makes perfect sense to me. Much appreciated. Hi everyone, Looking for some advise. We are about to build an above ground pool in our backyard. There is a private sewer line running under the pool at 1.6m… 0 11937 Hi, I'm new to this forum so I hope I'm doing this post correctly. Please advise if it's not. I've just bought my place. The inground pool has a marble lining that has… 0 13775 Murraya could be a great option for you. It creates a great tall screening hedge but doesn't drop fruit like lily pilly. The flowers smell divine. 2 10393 |
