Browse Forums Pools & Spas 1 May 23, 2021 8:32 am Hi All, The short version is that we have a 50kL concrete pool that is not required as part of our KDR. I would like to convert it into water collection and storage with a structurally sound roof cap that allows me to build a shed or entertainment area on top of it. I know it's possible, but is it realistic? We are in Brisbane but not BCC local govt. Any advice appreciated. Cheers RJ Re: Convert Pool to Water Storage 2May 23, 2021 4:13 pm I would tend to plan on putting a cover on then building an indpendent deck type structure with a space between the deck and the cover. Building somethng like a reinforced concrete roof that would do both would be expensive. The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Convert Pool to Water Storage 3May 24, 2021 9:03 pm https://www.cupolex.com.au/cupolex-hard-landscaping/ this system allows a structural slab on posts, you’d need an engineer who has worked with the product, tricky to tie into existing pool Re: Convert Pool to Water Storage 4May 24, 2021 9:39 pm You will also need a mosquito proof cover plus ventilation on the pool. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. consider putting in wall WC instead of robe in the same bedroom, then it might be doable to hook up to the existing piping. 4 6628 Hi everyone, Looking for some advise. We are about to build an above ground pool in our backyard. There is a private sewer line running under the pool at 1.6m… 0 11758 Hi, I'm new to this forum so I hope I'm doing this post correctly. Please advise if it's not. I've just bought my place. The inground pool has a marble lining that has… 0 13663 |
