Browse Forums Pools & Spas 1 Jan 11, 2021 12:44 pm Hi I am a tenant with a pool in NSW. Since we moved in a month ago we have struggled to get the pool water clear. I have since noticed significant bubbling of the fiberglass all over the pool and when you rub the side of the pool the water becomes cloudy. All of the pool chemistry tests are fine and calcium levels are also fine so I don't think its calcium build up. My question is does a landlord have to resurface an old pool, I think it's around 20 years old based upon dates the house was renovated? Is it a safety issue? Re: Does a landlord have to resurface an old pool? 2Jan 11, 2021 2:24 pm no a landlord does not have to resurface most likely is not a safety issue i would doubt your water chemistry is fine please list the numbers from a reliable test (note test used) and how the pool is chlorinated Approvals are covered in the cost we are paying to the pool company. The only thing stated in our home build contract for the additional cost is engineering support. … 3 7104 Is it possible to render an old corrugated iron shed.I have heard that it can be done if it is covered with chicken wire first.Not sure of the ratio of the render mix and… 0 4890 Thanks Chippy,I do have one that I levered out. I'll try to find a brand name on the windows then do some searching. Here is a photo where you can see how worn they are. 2 7947 |
