Browse Forums Pools & Spas 1 Oct 29, 2020 6:41 pm Hi, We have a property built on a very steep slope. The concrete in-ground pool is located at the bottom of the block some 10m below the house. After heavy rain that persists for a few days, our pool turns dirty. I am thinking it is either sorry surface water running in or groundwater pressure building up due to the slope and coming up through the hydrostatic value. Any people with a similar issue or thoughts on how to fix? I don't want to dig our ag drains on the slope between the house and pool if they won't be deep enough to to help the issue. If it is groundwater and with an existing pool, is there any way to fix? Thanks in advance Andrew Re: Pool fills with dirty after heavy rain over multiple day 2Nov 25, 2020 1:55 am It was not a good idea to build a pool on a very steep slope. It's definetely groundwater but I have no idea what whould be done. Re: Pool fills with dirty after heavy rain over multiple day 3Dec 02, 2020 6:37 am A lecturer I had many years ago described water as lazy as it takes the easiest path downhill. If the slope is very steep then the water will move quickly downhill. Can you do something to slow it and move the water to where you want rather than towards the pool. Maybe creek bed looking landscaping that carries the water to where you want it to go? The bottom of the downpipe has been taped (see the black tape) to seal the necessary gap between the downpipe and the adaptor that would normally prevent the downpipe… 3 9242 Firstly, if your house is still under builder's warranty (10 years in Victoria) you should have no need to crawl into roof space but let the builder handle it, unless you… 3 5644 What size are the windows, double or single glazed, can I have a pic of the full windows inside & out? If you can see packers please take a pic. 1 12406 |
