Browse Forums Pools & Spas 1 Sep 15, 2020 10:37 pm We will move into a new place in NSW where we will have to make the pool fence compliant. The issue is a sliding living room door leading into the pool area as per pictures. Could we: a. Erect a compliant pool glass gate just in front (say 50mm) of the existing sliding door which would open into the living room once the sliding door is open? Would that offend any of the NCZs? or b. permanently screw the existing door shut by some fixtures blocking door to open at all? Access to the pool area would then be through a gate outside the house. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: How to fix non-compliant building door to pool? 2Jun 15, 2021 8:02 am Hi there I was wondering what solution you came up with for the pool sliding door? I want to change my pool fence and a door would form part of the space. I was thinking perhaps a piece of fixed of fence to block it or fixed security mesh over the whole door. I can’t find much info on the web about these types of options. Thank you! Building Standards; Getting It Right! Hi, yes, we have the report. The builder has rectified the items on the report and we’re moving forward with the build. Thanks for reaching out 2 2488 From a pure legal perspective, if you've signed the variation, it is a very high bar to have it set aside. No-one can give you legal advice on a forum, but you would need… 3 5478 Thanks. There are plenty of builders around my suburb. I'll make sure to do some door-to-door knocking, or note their building details on the temp fence. 4 4747 |
