Browse Forums Pools & Spas Re: Pool Fencing with Boundary Fence Help 2Sep 18, 2020 8:41 pm I have a question. Given that pool fencing needs to be 1200mm high with no gaps larger than 100mm but if your pool uses a perimeter fence, that needs to be at least 1800 high. Can you use a decorative fence extension to comply with the height minimum 1800mm height ? ask the surveyor for clarification would be the logical approach 1 15967 thanks Chippy, i hope they have applied sealer but i am doubt to be honest, so i am gonna do this job after handover. 8 11891 You should be able to encase the sewer but you will need it designed and approved and access to lot 580 to do the work 2 12627 |
