Browse Forums Pools & Spas 1 Nov 22, 2020 11:27 am Hi all. I have an outdoor salt/chorine pool in Hobart (yes we only use it for 3 months a year) im not great with terminology but please if you have any ideas your suggestions would be much appreciated...but its leaking and we can't work out where from. The water level frequency drops below the skimmer box. The heat inlet pipes we have blocked off and don't appear to be leaking. There is no access to the underside of the pool unless we break through and make a massive mess How can I locate the leak? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Out door pool issues - leak 2Nov 22, 2020 12:24 pm You are on elevated ground and all pools are subject to evaporation. Just monitor the daily levels for a few weeks in between rain. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Out door pool issues - leak 3Nov 22, 2020 1:25 pm Cheers I should have mentioned I also can see the leak coming out, on the footpath. But no idea where it comes from. Re: Out door pool issues - leak 4Nov 22, 2020 1:30 pm Ok...that makes a difference. Good luck with it. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. If you make sure all taps inside and out are turned off, what does the water meter show if you leave it for a while. 2 16233 Hi all, I am hoping someone has some ideas as to what is causing my bathroom leak. The leaking appears to mainly happen when we turn the sink basins on. It takes a while… 0 4026 DIY, Home Maintenance & Repair Are you doing this with a building permit? Conversion of a non habitable room into a habitable room requires building permit. 3 13421 |
