Browse Forums Pools & Spas Re: Distance between pool, house and boundary 4Feb 05, 2017 12:02 pm Building Casaview Denison 30 https://fortdenison.wordpress.com/about Re: Distance between pool, house and boundary 6Feb 05, 2017 1:59 pm Building Casaview Denison 30 https://fortdenison.wordpress.com/about Re: Distance between pool, house and boundary 8Mar 12, 2017 6:20 am xyz I am a little bit worrying about my neighbours who put their pool quite close to the boundary. 80cm to the to-be water line. Blacktown council (NSW). Is it legal? I'll take a guess here. If you are able to measure that it's 80cm, then they might be allowing 15-20cm concrete wall and tiling. It's only a guess Good luck Good on you for having a go I am the opposite of DIY (so will pay a builder) - our vibe is industrial/simple so current thinking is 150mm concrete and then internally is… 3 3177 Found the answer. The recommended distance is .... 1 6319 You should be able to encase the sewer but you will need it designed and approved and access to lot 580 to do the work 2 17922 |
