Browse Forums Kitchen Splashbacks 1 May 27, 2013 10:55 pm Was recently given a bunch of Stainless Steel Mosaic Tiles, Rectangle in shape on a sheet. The tiles are Stainless Steel Cap with the Ceramic backing on them. Easy enough for a tiler to put up but a nightmare for a tiler to cut each tile correctly. I have been trying to find a tiler that has experience with these types of tiles that can tile my Kitchen. I have a fair few corners in my layout so a lot of cuts needed to the tiles. I have been reading the correct method for a tiler to cut these using a wet saw with a diamond rimmed blade as this does not allow for scorch marks on the metal. Can anyone recommend a Tiler in the Sydney Area that can do this using this method? Brass or 2) Stainless steel made - which Kitchen tap is good for drinking.Brass kitchen taps in Australia contain lead… 0 6701 Hi I am wanting some opinions about the build of a steel shed I am going to get one about 4.5 x 2.5 m steel shed and the height will be about 2.3-2.4m high The one I am… 0 14389 Regardless of wall hung toilet or floor pan toilet your feet will be right on drain, seems to me the waste should not be in that location given the design. Also are you… 6 7020 |
