Browse Forums Kitchen Splashbacks 1 Aug 21, 2012 1:04 pm I have just fitted our kitchen in our new home and one of the last things we need to do is the splashback. My wife and I agree on a metalic red as the colour we want for the splashback. The only problem is that we can find any that we like. All of the metalic red glass splashbacks we have seen have had far to much silver in them. Does anyone have photos of a similar colour or any ideas where I could send my wife to look at them? I dont want to waste my suppliers time and have him spray up a number of different samples. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Metalic Red splash back. 3Aug 24, 2012 7:57 am I dont actually have any names. My supplier had 3 in his showroom and we also had one made up. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Metalic Red splash back. 4Aug 24, 2012 8:30 am You could try doing the splashback in Acrylic. There is a huge range of colours and I have seen quite a few done and they look very impressive. A bank is a place that will lend you money only if you can prove that you don't need it... Re: Metalic Red splash back. 5Aug 24, 2012 10:40 am Could you post an example of what you mean by metallic red? Anything will do....like a car? Re: Metalic Red splash back. 6Aug 28, 2012 2:18 pm This is the colour we are after but with a metalic in it. All the metalics we have seen have had alot of silver them. Far to much! Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Metalic Red splash back. 8Mar 20, 2013 11:41 pm There are 2 ways splashbacks are made with metalics from some suppliers. If you say there is too much metalic than i would say its when they spray a sparkle down on glass first than apply the colour after, this is common as they just use standard paint instead of metalic paint. The problem when they spray the sparkle down if sprayed heavier on 1 panel to the other it can be very noticeable. The paint we use comes from BC Coatings which they will make up any colour of your choice and than add metalic to the paint. The metalic paint also comes in Fine, Medium or Coarse metalic so you can control the amount of sparkle by using a fine metalic. Hope this helps. Our Bondi Greenwall was impressive from day one with advanced lush plants to provide a wow factor to this recently renovated living area. The boundary was less than 1… 0 15293 I’m restoring all my 40yr old windows and I want to install seals around the casements. I’ve sanded back and oiled the frames with sikkens. My plan is to box up inside… 0 6506 My land is 260m2 (10m x 26m) located in claymore NSW. Under campbelltown council. I know in general the following setbacks would apply ground floor side setback =… 0 6897 |
