My 20 year old kitchen is being upgraded by Granite Transformations in a month or so. The splashback will be the same as the benchtop (ie granite).
It is currently a largish U shaped kitchen (or I guess you could say it's also an L shaped kitchen with a breakfast bar, making it a 3 sided kitchen):
* the right hand side has the fridge, oven stove and overhead cupboards,
* the middle section has the sink underneath the window, then a microwave cupboard over the bench to the left of the window
* the left hand side is a breakfast bar - on the other side of the breakfast bar is a living area with a table etc.
At the moment, the splashback underneath the microwave cupboard goes to the height of the microwave cupboard (which has a bulkhead that goes right up to the ceiling). We are ripping down the microwave cupboard and moving the microwave into a space underneath the breakfast bar.
My question is whether you think the splashback where the microwave cupboard used to be should be the same height as the splashback on the right hand side of the kitchen (ie 700mm), or whether it should just be the same height as the splashback under the kitchen window (ie 200mm) - that is, the splashback under the window will just keep continuing at the same height to the left of the window, until the edge of the breakfast bar.
My concern is that if the splashback is 700mm high to match the height on the right hand wall, it will look too high and out of place. It might look a lot neater if the splashback goes from 700mm on the right hand side, drops down to 200mm underneath the window and just continues along the same wall as 200mm, rather than jumping back up to 700mm on the other side of the window.
I realise it would be a lot easier to show what I mean if I could show you a picture, but I haven't worked that out yet!!!
I would appreciate any comments/suggestions.
