Browse Forums Kitchen Splashbacks Re: Splashback requirements - Australian standards????? 29Mar 28, 2023 12:09 pm alexp79 wouldn't any stone be fire retardant? a real stone would, but engineered stone isn't actually a real stone. probably good example of why the certificates are required, just because marketing gives something a common name, doesn't mean that this something will inherit all the properties. Building Standards; Getting It Right! Don't think they are designed for double brick. WA has a particular way of building and unfortunately that's the way a large amount of sills are finished. 3 7235 I believe this is correct. From the picture you can see the power was put in last so the electrician knew where the water was. Really it's a common sense issue more… 4 5270 2 8900 |
