Browse Forums Laundry 1 May 11, 2008 5:37 pm Following on from post 1,386,232 in Phoenix's (home build) thread I though I would start a dedicated thread to this subject so it didn't get lost!
The days of needing to have all your cable and pipes running above the counter tops are over people! Long live u bends in plumbing and hole saws for cabinetry! This is my laundry: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The first thing people look for is the cables to "hook it up" ... these are not props...they are real! Even when facing straight on it is near impossible to tell where the cables are. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Once you get right in with a flash the secret is revealed: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ We even did the same thing with our Clothes dryer: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Under the sink is where the magic happens... Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The cables at the back are the hot and cold taps and the black hose at the front with the silver cable clamp on it is the waste! The one that usually hangs in the hole beside the sink in most laundry troughs! Not anymore! A couple of well placed 50mm holes with a hole saw and some pre planning with the electrical helps too! Re: Laundry pipes and power cables 3May 11, 2008 6:31 pm Re the blue which is visible around the door in the first two photos - Have you got a hose full of neons, you doof doof hoon you? Geoff - Decophile. Re: Laundry pipes and power cables 4May 11, 2008 6:34 pm Eager Re the blue which is visible around the door in the first two photos - Have you got a hose full of neons, you doof doof hoon you? Great set up, when I went through the new house I must admit I had to search for the taps!! Told DH a new washer and dryer were needed for the set up!! Paula Re: Laundry pipes and power cables 6May 11, 2008 8:09 pm This is what I love about this forum! Everyone sharing their little secrets so complete novices like me can add it to our list of additions! I hadn't seen this before, as most display laundrys just have the trough and no other cupboards and options (well, the ones I have looked in!).
This is a brilliant way to keep eveything looking minimal and neat (very much lacking in my current box), and I will most definitely be asking for concealed taps, waste and power points in the laundry....love it!! Thanks Matt! Henley - Wilshire Mk 3 ... I love my house!! Site start: 4th Feb 09 Handover: 10th Sep 09 Blog: http://stormygirlscastle.blogspot.com/ Build Thread: viewtopic.php?t=7166 Re: Laundry pipes and power cables 8May 12, 2008 9:45 am oznow,
Currently we have a door to the garage to the right of the picture that is left open when the dryer is running. I haven't vented this unit as it doesn't have a rear vent (its 146 years old!!!!) but if and when it gives up the ghost I will install a unit with a rear vent kit! Re: Laundry pipes and power cables 9May 12, 2008 10:25 am Our builder puts the taps under the sink as standard, but I didn't even think of the powerpoints... should have put them in the cupboards too. Nevermind, I can live with that.
Ray. Second Time 'Round Building Standards; Getting It Right! Thank you for the generous offer. I need to get the plumber out to give me an explanation. As mentioned I haven't seen any rain water discharge from pipes 1& 3. It… 7 10834 4 5122 As most others have posted above the install isn't compliant. The pipe is meant to be covered in loose soil or sand, the pipe has holes in it that leaks out a termicide… 10 5730 |
