Browse Forums Laundry Re: Rainwater BASIX requirements 4Jul 08, 2024 11:24 am 3in1 Supadiverta. Rainwater Harvesting Best Practice using siphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost, siphonic, eaves gutter overflow solution. Re: Rainwater BASIX requirements 6Jul 08, 2024 1:43 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using siphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost, siphonic, eaves gutter overflow solution. Re: Rainwater BASIX requirements 7Jul 10, 2024 3:35 pm Sleepless Knights Due to BASIX, rainwater connection is to be connected in the laundry. Does anyone know, if can be bypassed or feasible work arounds? TIA You can ask the plumber to run 2 pipes to you laundry. One connected to the mains and one to the tank ( i did this in my home) I find that if you just turn your pump off to the tank the water pressure is weaker as there is some type of valve the water needs to pass through which affects pressure Architectural Homes & Duplexes - specialising in custom designing homes to your budget Get a Free Onsite Consultation Today or send a PM for information, questions or advice. BASIX is fairly simple but the thermal comfort potion of BASIX is the most difficult. It’s best to have an energy assessor rate the house rather than using the BASIX… 6 7405 Hi there, It's likely that the BASIX created in 2022 was done so on the old BASIX Portal (no longer in use) and based on the old legislation. The BASIX standards… 1 3498 Building Standards; Getting It Right! You should have a waterstop at your shower and again at any entry to the bathroom. As the bathroom includes an unenclosed shower the main floor of the bathroom Must grade… 3 2835 |
