Browse Forums Laundry 1 Aug 10, 2017 10:19 am Hi, We are about nearly ready to do selections for the laundry. We just bought a new washing machine (out front loader died) and have a front loader for the first time. Both dh and I are quite tall and have found it a long way down to put in the washing and take it out again. Is it worth raising the front loader? We have heaps of room in the laundry, so can be flexible with design. The plan at the moment is to have overhead cupboards over the washer and dryer with a handing rail. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Raised front loader 2Aug 13, 2017 10:58 am I have mine sitting on a metal cabinet that was bought about a month after I bought my front loader. I found the bending down to look inside for the lost sock a nuisance, and have not regretted raising the washing machine. The big drawer is just fantastic - you can never have too much storage! The dryer sits on top and is easily accessed at eye level too. It would mean you would lose bench space in your current plan. I notice you have a window next to the tub - does your door have a glass inset? If so, you might find that it would provide enough light into the room, and you could put your wm/dryer against the outside wall (where the tub is now) so a pipe can be fitted to vent the dryer directly outside. Set the tub in the bench and continue along the whole wall. Put the broom cupboard on your opposite wall. Sorry! I've just rearranged your entire layout! Just my thoughts....good luck with the decisions. Re: Raised front loader 3Aug 14, 2017 4:10 pm thanks for the thoughts The door is a plain wooden door which is why we have the little window but might talk to builder about putting a window in the door instead. But sounds overall that raising the washing machine can work We are planning on something like this for the empty side of the laundry to help with sorting laundry, plus space for the kitty litter and cat food etc. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Raised front loader 4Jan 03, 2018 9:48 am Our laundry with raised dryer and washer. Best thing ever not having to bend down to get washing in and out!!! I don’t have heaps of benchtop but it’s more than enough as I don’t like folding clothes in there, I do it on the lounge or using our “desert” kitchen island. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Owner Builders in boot-shaped Yorke Peninsula : viewtopic.php?f=38&t=80264& Re: Raised front loader 5Dec 22, 2018 9:10 am Just to raise an old post: I have been speaking to my builder about raised front loader and dryer in our cabinetry designs. I think this is an excellent idea, but the builder has advised against it. they say there will be too many vibrations that affect all the adjoining cabinetry. Anyone has any experience on cons of a raised washing machines? Raised front loader 6Jul 11, 2021 5:04 am mboy Just to raise an old post: I have been speaking to my builder about raised front loader and dryer in our cabinetry designs. I think this is an excellent idea, but the builder has advised against it. they say there will be too many vibrations that affect all the adjoining cabinetry. Anyone has any experience on cons of a raised washing machines? Owner Builders in boot-shaped Yorke Peninsula : viewtopic.php?f=38&t=80264& thanks chippy! here is the back of the wall which has not been backfilled yet. Here is the same back of the wall taken from the other end, behind the steps. As you… 5 1401 Get some long brass machine screws and bolt right through the gate and put brass acorn nuts and washers on the other side. It will never come off 1 9319 that will depend on the kitchen bench depth. you'll have to specify it so it allows for both the tap and the sink 1 7791 |
