Browse Forums Laundry 1 Feb 06, 2021 2:10 pm G'day I am curious about my laundry floor, I have removed the old tiles and am going to lay new tiles, but the floor is very uneven, in some parts the floor adhesive previously was in some parts 2 inches thick and some parts not even a centimetre thick, I do not want to replicate that but know that i have to have the floor slightly lower for the drain. Should I lay a thin layer of cement first then retile? Re: Laundry floor 2Feb 06, 2021 2:26 pm What you are seeing is not tile adhesive but the screed (sand and cement) that tilers use to form the fall into the floor. The tiles are then stuck to the screed. When you remove the tiles often the screed is also ripped up in patches. You have two options. First, you rip up all of the screed and then re-screed the floor. Second, you patch the existing floor screed. Whatever you do, you need to make sure that the surface under the tiles is nice and flat (no lumps or hollows) and is sound. That will give you the best chance of getting the tiling looking good and not having any issues down the track. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 The requirement is for a waterstop to be installed to the entries of the room, (a small aluminum 'L' angle to retain the water to within the room) can't see if they have… 1 1938 This is a very tight fit, I'm not sure if you'll be able to achieve what you've described. Would you consider accessing the separate toilet from the laundry? If so maybe… 1 11252 |
